メインコンテンツにスキップ
Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Placement: 手順 1、 1の画像 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Battery Door Removal: 手順 2、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Battery Door Removal: 手順 2、 2の画像 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Battery Removal: 手順 3、 3の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Battery Removal: 手順 3、 3の画像 2 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Battery Removal: 手順 3、 3の画像 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Heads Up!: 手順 4、 1の画像 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Screw Removal: 手順 5、 1の画像 1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Prying: 手順 6、 1の画像 1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Remove Housing: 手順 7、 1の画像 1
    • Lift the rear housing from the display assembly.
  8. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Logic Board: 手順 8、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Logic Board: 手順 8、 2の画像 2
    • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
  9. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 9、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 9、 2の画像 2
    • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
  10. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 10、 1の画像 1
    • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
  11. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 11、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 11、 2の画像 2
    • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
    • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
  12. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 12、 1の画像 1
    • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
  13. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 13、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 13、 2の画像 2
    • You have now removed the logic board from the display assembly.
  14. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Remove Flex Cable: 手順 14、 2の画像 1 Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement, Remove Flex Cable: 手順 14、 2の画像 2
    • Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
  15. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 15、 1の画像 1
    • Flip the logic board to the front, and using a spudger/plastic pry tool to push the tension clip away from the board that holds the speaker/rear camera.
  16. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 16、 1の画像 1
    • Flipping the board back over, remove the speaker/rear camera by lifting from the right side as shown.
    • Be careful not to rip the ribbon cable when you disconnect the speaker/rear camera cable connector.
  17. Samsung Galaxy Attain 4G Speaker/Rear Camera Replacement: 手順 17、 1の画像 1
    • The speaker/rear camera has now been removed from the board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Josh Forester
メンバー登録日: 11/28/10
2,558 ポイント
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 297
