はじめに
Remove a faulty motherboard from the phone to be replaced with something functional. You may need to replace the motherboard because of water damage or if there are problems with functionality. It is advised that care is used when removing the motherboard to avoid damaging the rest of the phone.
必要な工具と部品
Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
Lift upwards and gently pry the rear panel off of the phone.
Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
Disconnect the connector piece from the back panel.
Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
Push from the back panel to remove the bottom part of the motherboard.
Push from the front panel to remove the top part of the motherboard.
