はじめに
You will need a PH00 screwdriver - one of the most commonly used screwdrivers on mobile phones. If you have ever even attempted anything with phones before you probably have dozens of them lying around.
A metal and plastic spudger are recommended but not required - if you lack these, strong fingernails are an adequate stand in.
必要な工具と部品
This is the first time I have seen this phone in my life.
I received it from a friend who informed me I needed to replace the digitiser, and would be rewarded with $20 for doing so.
Cracked display, the reason for replacing the glass digitiser on the front.
Locate the small hole on the left side of the phone near the volume rocker, which you can slip your fingernail into to pull the battery casing off.
On the Ace 2e model, the small hole is on the top of the device.
Instructions were great - all seemed to go well, but the screen doesn't seem to respond correctly - can only type a couple of characters before it locks, swipe doesn't seem accurate - like it needs to be calibrated. Any ideas?
I'm not sure as I don't work with Samsung devices. Your replacement sounds like it is defective though. (Unless you mean the device is locking, which shouldn't be happening)
Tom Lube -
Heat the entire front of the display up with a heat gun. A hair dryer will work as well.
Stick a finger nail in an area with a small seam - I found one around the top right - and pry it open just enough to fit a spudger.
Run it all the way along the edge of the display. There are no sensitive ribbon cables to break, but pay close attention to the silver speaker at the top, and the home button at the bottom.
26 の人々がこのガイドを完成させました。
14 件のコメント
Thank-you so much for helping me out and for answering my question. But as I said before, my phone is unresponsive to my touch. Do you think that problem will be fixed after replacing the screen as shown above?
Hey mate, unresponsive to touch is a sure sign that the digitiser is shot. Getting a new one will almost certainly resolve this issue.
Tom Lube -
my daughter smashed her screen and was ready to have us buy a new phone, I said lets order a screen and see if we can fix it. Well it took 2 weeks for the ebay screen to arrive, and then I had to putup or shutup. It did take about a 1/2 hour and then she put the sim chip in backwards which scared the crap out of me, but for $7.50 her phone is working. Oh I made a mistake and got a black faceplate but she says it looks better in black. So Thanks, and just mention that that screen gets hot with a blow dryer, but a thumb nail works id off just fine
w a powers - 返信
Hey mate! Glad to hear you had a success with the replacement :) Good for you all!
And yes, the screen is meant to get really hot (more hot than is comfortable to the touch) but don't worry if you did it another way :)
Tom Lube -
Well thanks again, two months after replacing the screen the kid broke the new one, so it took two weeks for the new one to show up and the cost went up by 5 cents. One thing in step 9 I had forgot (!@#$ I'm almost 70 I forget lots of stuff) that the lock flips up from the back to the front. And then getting the tab back into position was a real pain. I can only see out of 1 eye so I need to hold the magnifying glass, hold the lock up and fit the tab in. Easy for you young whipper snappers, but for geezers it's a handful
Thanks again great explainations and photos
w a powers - 返信
Hahahaha I'm really glad man! Thanks for the kind words :)
Tom Lube -
My screen is fine but dust has crept inside under the glass. Is there a shortcut to get to the inside of the glass? Otherwise I just follow the steps provided. I'm guessing I'll have to follow most of then anyway to get the electronics away from the cover before I use the heat gun!
Jean Lemire, October 10
Hey mate!
Yes, you cannot skip these steps. Not because of the electronics, but rather the plastic!
Let me know if there are any other differences & I will update the guide as appropriate.
Tom Lube -
i just changed my phone's screen and digitizer but now the touch screen won't work. i see in some youtube videos and also read some comments to wipe the led with alcohol. i also read to brush the motherboard and contact points and again with alcohol. can i do that with samsung galaxy ace 2x too? what do you that? thanks.
Sure, you could do this. Don't know if it will help any!
Tom Lube -
Hi, have one of these here. How do you tell if it is a bonded screen versus just contact? I don't want to take this apart and make it worse, on this one the OLED is OK (barely) but the glass is smashed beyond recovery so its going to be a tape job for sure.
Also I found that at least for the S4 mini it is actually feasible to use a hair drier and optical reader strip from a dead HP all-in-one printer as this seems to have the right tensile properties to separate the glass on some bonded screens without damaging or scratching the OLED glass. Sometimes if you did scratch it there is a chance of successfully repairing it by replacing the top UV and polarizer layer with some Xylene to break the glue, or simply hope that the LOCA re-bonds everything and fills in the scratches.
Incidentally I am in the market for a Neo mainboard if anyone has a spare, this one has broken power socket.
I have this phone I am trying to recover pictures from it any way to find the schematics of it
