メインコンテンツにスキップ
Samsung Galaxy A71 Charging Board Replacement
必要な工具と部品
ビデオの概要
Samsung A71 Charging Port Replacement
  1. Samsung Galaxy A71 Charging Board Replacement, Charging port: 手順 1、 3の画像 1 Samsung Galaxy A71 Charging Board Replacement, Charging port: 手順 1、 3の画像 2 Samsung Galaxy A71 Charging Board Replacement, Charging port: 手順 1、 3の画像 3
    • A look at the new charging board.
  2. Samsung Galaxy A71 Charging Board Replacement, Back cover / Battery cover removal: 手順 2、 3の画像 1 Samsung Galaxy A71 Charging Board Replacement, Back cover / Battery cover removal: 手順 2、 3の画像 2 Samsung Galaxy A71 Charging Board Replacement, Back cover / Battery cover removal: 手順 2、 3の画像 3
    • Now we are going to separate the back cover. First, warm up the device to soften the adhesive, then use a plastic spudger to open up the rest of the device.
    • Take care when removing the back case as too not damage anything.
  3. Samsung Galaxy A71 Charging Board Replacement, Phillips screws and SIM Tray: 手順 3、 2の画像 1 Samsung Galaxy A71 Charging Board Replacement, Phillips screws and SIM Tray: 手順 3、 2の画像 2
    • Remove all Phillips screws and the SIM Tray.
  4. Samsung Galaxy A71 Charging Board Replacement, Middle frame removal: 手順 4、 3の画像 1 Samsung Galaxy A71 Charging Board Replacement, Middle frame removal: 手順 4、 3の画像 2 Samsung Galaxy A71 Charging Board Replacement, Middle frame removal: 手順 4、 3の画像 3
    • Use your spudger once again to separate the middle frame. Be careful to take your time here as well so you don't damage anything.
  5. Samsung Galaxy A71 Charging Board Replacement, Battery, Main flex cable, etc.: 手順 5、 3の画像 1 Samsung Galaxy A71 Charging Board Replacement, Battery, Main flex cable, etc.: 手順 5、 3の画像 2 Samsung Galaxy A71 Charging Board Replacement, Battery, Main flex cable, etc.: 手順 5、 3の画像 3
    • Disconnect the battery. Make sure not to puncture it.
    • One by one disconnect:
    • Display flex cable.
    • Coaxial antenna connector.
    • Fingerprint Sensor.
    • Main flex cable.
    • Remove the two Phillips screws securing the Fingerprint sensor.
  6. Samsung Galaxy A71 Charging Board Replacement, Installing the new charging board.: 手順 6、 2の画像 1 Samsung Galaxy A71 Charging Board Replacement, Installing the new charging board.: 手順 6、 2の画像 2
    • Carefully pry out the old charging board, and put in the new one.
終わりに
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,470 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,479のガイドは作成済み
5 件のコメント
Great guide! I recommend removing the Fingerprint Sensor as a whole. It will make it easier to remove the board, as the charging board has some adhesive, so you will need to pull a bit harder.
When screwing the sensor back, make sure to not tighten each screw all the way at first, but instead alternate between tightening one screw and the other. This will make sure that the sensor is properly aligned! This fixed the issue I was facing with reading some fingerprints after I had my screen replaced by a third party repair shop a couple of months ago. Two birds with one stone!
Festest - 返信
This guide will help you to replace the charging board - definitely not too difficult. I replaced my board after my A71 stopped charging when I inserted the USB C cable. First it wouldn't fast charge and then wouldn't charge at all.
Callum - 返信
Thanks man, got it done in roughly half an hour! My phone would charge but not transfer data and this seems to have fixed it.
Majik - 返信
The guide was very excellent, however after putting the components all in place and booting back into the OS, the finger print reader refused to work anymore (both the original and a replacement one) and as far as i could tell there was no damage to where the reader connects. However, a more important issue is that with the replacement board my phone refused to recognize having the sim card inserted. If there is any software nonsense I have to go through it would be appreciated to have a pointer but at the end I had to fix the USB C port on the original board and reinstall it.
Samuel - 返信
My sims no service after they made my old charger port. Is there any help please?
StaphaySalone - 返信
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 100
過去 30 日: 469
今までの合計 15,769
