メインコンテンツにスキップ
Samsung Galaxy A52 Loudspeaker Replacement
必要な工具と部品
  1. Samsung Galaxy A52 Loudspeaker Replacement, Heat the back cover: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A52 Loudspeaker Replacement, Insert an opening pick: 手順 2、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A52 Loudspeaker Replacement, Slice the adhesive: 手順 3、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. Samsung Galaxy A52 Loudspeaker Replacement: 手順 4、 3の画像 1 Samsung Galaxy A52 Loudspeaker Replacement: 手順 4、 3の画像 2 Samsung Galaxy A52 Loudspeaker Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick underneath the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A52 Loudspeaker Replacement: 手順 5、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom edge of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A52 Loudspeaker Replacement: 手順 6、 3の画像 1 Samsung Galaxy A52 Loudspeaker Replacement: 手順 6、 3の画像 2 Samsung Galaxy A52 Loudspeaker Replacement: 手順 6、 3の画像 3
    • Insert a fourth opening pick underneath the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A52 Loudspeaker Replacement: 手順 7、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A52 Loudspeaker Replacement, Remove the back cover: 手順 8、 1の画像 1
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A52 Loudspeaker Replacement, Unscrew the motherboard cover: 手順 9、 1の画像 1
    • Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
  10. Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: 手順 10、 3の画像 1 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: 手順 10、 3の画像 2 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the motherboard cover: 手順 10、 3の画像 3
    • Insert an opening pick underneath the left edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Remove the motherboard cover.
  11. Samsung Galaxy A52 Loudspeaker Replacement, Disconnect the battery: 手順 11、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement, Disconnect the battery: 手順 11、 2の画像 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    The daughterboard cover needs to be removed as well before proceeding to step 12
    Laurens Bolle - 返信
  12. Samsung Galaxy A52 Loudspeaker Replacement, Unscrew the loudspeaker assembly: 手順 12、 1の画像 1
    • Use a Phillips screwdriver to remove the six 4.4 mm-long screws securing the loudspeaker assembly.
  13. Samsung Galaxy A52 Loudspeaker Replacement, Pry up the loudspeaker assembly: 手順 13、 2の画像 1 Samsung Galaxy A52 Loudspeaker Replacement, Pry up the loudspeaker assembly: 手順 13、 2の画像 2
    • Insert the pointed end of a spudger into the gap on the right edge of the loudspeaker assembly.
    • Pry up the loudspeaker assembly.
  14. Samsung Galaxy A52 Loudspeaker Replacement, Remove the loudspeaker assembly: 手順 14、 1の画像 1
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 の人々がこのガイドを完成させました。
Adriana Zwink
メンバー登録日: 12/18/19
48,256 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
コメント 1 件
Excellent and very detailed tutorial thank you! Do you know what the impedance of the loudspeaker should normally be? After changing the charging port and reassembling my phone the loudspeaker is not working anymore. Many thanks in advance. Emmanuel
Gfggrrrddd hg - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 139
今までの合計 3,388
