メインコンテンツにスキップ
Samsung Galaxy A52 Back Cover Replacement
必要な工具と部品
  1. Samsung Galaxy A52 Back Cover Replacement, Heat the back cover: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A52 Back Cover Replacement, Insert an opening pick: 手順 2、 2の画像 1 Samsung Galaxy A52 Back Cover Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • If the back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A52 Back Cover Replacement, Slice the adhesive: 手順 3、 2の画像 1 Samsung Galaxy A52 Back Cover Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. Samsung Galaxy A52 Back Cover Replacement: 手順 4、 3の画像 1 Samsung Galaxy A52 Back Cover Replacement: 手順 4、 3の画像 2 Samsung Galaxy A52 Back Cover Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick underneath the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A52 Back Cover Replacement: 手順 5、 2の画像 1 Samsung Galaxy A52 Back Cover Replacement: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom edge of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A52 Back Cover Replacement: 手順 6、 3の画像 1 Samsung Galaxy A52 Back Cover Replacement: 手順 6、 3の画像 2 Samsung Galaxy A52 Back Cover Replacement: 手順 6、 3の画像 3
    • Insert a fourth opening pick underneath the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A52 Back Cover Replacement: 手順 7、 2の画像 1 Samsung Galaxy A52 Back Cover Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A52 Back Cover Replacement, Remove the back cover: 手順 8、 1の画像 1
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
終わりに
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
11 の人々がこのガイドを完成させました。
Adriana Zwink
メンバー登録日: 12/18/19
56,342 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,465のガイドは作成済み
2 件のコメント
When I opened mine there are writings. I dont know who wrote them but writen with a blue pen. This is weird. I never opened my phone. It just popped open and the adhesive is not sticky anymore
Bonevie G - 返信
It is from the factory. This is normal for Samsung phones.
RYRY1002 -
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 115
過去 30 日: 355
今までの合計 15,245
