はじめに
Use this guide to replace a broken display or cracked glass of your Samsung Galaxy A5.
必要な工具と部品
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift the back cover to insert an opening pick.
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card at the bottom and slide it underneath the back cover.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
With a flat end of a spudger disconnect the display connector.
Reheat the iOpener and use it to loosen the adhesive under the display.
On the left hand side (where the motherboard sits) replace the opening pick with a plastic card to get to the glue behind the battery.
Continue separating the adhesive until you reach the display cable.
63 の人々がこのガイドを完成させました。
8 件のコメント
dear sir,
i follow the steps above but still my mobile with black screen and colored dots, what shall i do please help me
Dear sir
Mera Mobile gir jane ke karan screen tut gya h but work kar rha mai chahta hu ise repair karwana please contact me Mobile -7903248447
Miei parole ci sono sei molto bravo , grazie mille per tutorial , e ti mandò un mondo di salute e più grande fortuna dell' mondo Grazie…..
Unfortunately, Croatian is not yet available on our site. A team of volunteers has already started localizing the iFixit user interface into Croatian, but there is still lots of work to do. We are using an open web translation software which is called "Crowdin". If you'd like to participate, you can just follow this link and create an account to start translating: https://crowdin.com/project/ifixit/hr# , but I would recommend that you read the iFixit translator guidelines first: Translator Guidelines Crowdin. If you’d like to get a notification as soon as we get started with Guide and Wiki translations in Croatian, you can just fill in this form:++ https://docs.google.com/forms/d/e/1FAIpQ.... I stay at your disposal for any further question or concern!
Salve vi ho trovato tramite un e-commerce in cui stò cerando di capire se posso o meno riparare il mio display di smartphone ed ho letto con piacere le vs. guide sopra e sono veramente spiegate molto bene complimenti per le foto ed i passaggi chiari e semplici .
Chiedevo solo queste ulteriori informazioni
Stò cercando poi il suo ricambio originale (Galaxy A5 (2016) Mod. SM-A510F Display Screen and Digitizer ) ovviamente Samsung piuttosto che uno compatibile o equivalente e chiedevo per caso se il Vs. che avete in store qui è già un prodotto originale ?
Avete per caso anche una guida per il rimontaggio della parte nuova sostituita Display ? Serve pulire le parti smontate con prodotti specifici ed anche nel rimontaggio (collanti o adesivi specifici ) e se si quali prodotti ?
Grazie molte per la Vs. risposta/e
Andrea M.
The spare part in our store is an OEM part, yes.
To re-assembly the device follow the guide in reverse (and look out for notes, regarding the re-assembly in particular). The spare part comes with pre-installed adhesive so you should be fine. Cleaning some areas from remnants is always good to prepare for re-assembly especially adhesive residue on the frame. For that you can use isopropyl alcohol (>97%).
I wish you a successful repair
i trrursat mobile repair
