メインコンテンツにスキップ
Samsung Galaxy A40 Charging Board Replacement
必要な工具と部品
ビデオの概要
  1. Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: 手順 1、 2の画像 1 Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: 手順 1、 2の画像 2
    • The spare part: Daughter board with Charging port, Microphone, Main flex cable connector, display connector, 3G, 4G antennas
  2. Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 手順 2、 3の画像 1 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 手順 2、 3の画像 2 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: 手順 2、 3の画像 3
    • Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
    • To soften the adhesive, use a heat gun or heating pad to warm up the device.
    • Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
  3. Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 手順 3、 3の画像 1 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 手順 3、 3の画像 2 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: 手順 3、 3の画像 3
    • Be very careful when removing the ribbons in this step! Damaging the ribbons may cause parts of your phone to stop working
    • Remove the SIM tray.
    • Remove the plastic cover that covers the Fingerprint flex connector.
    • Disconnect the Fingerprint Sensor.
  4. Samsung Galaxy A40 Charging Board Replacement: 手順 4、 3の画像 1 Samsung Galaxy A40 Charging Board Replacement: 手順 4、 3の画像 2 Samsung Galaxy A40 Charging Board Replacement: 手順 4、 3の画像 3
    • Remove the 13 screws
    • Remove the back cover
  5. Samsung Galaxy A40 Charging Board Replacement: 手順 5、 2の画像 1 Samsung Galaxy A40 Charging Board Replacement: 手順 5、 2の画像 2
    • Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
    • Remove the black screw securing the charging board.
  6. Samsung Galaxy A40 Charging Board Replacement: 手順 6、 3の画像 1 Samsung Galaxy A40 Charging Board Replacement: 手順 6、 3の画像 2 Samsung Galaxy A40 Charging Board Replacement: 手順 6、 3の画像 3
    • Use Plastic tool to separate the charging board from the frame.
    • Warm the charging board slightly to make it easier to disassemble.
    • Now, install the new board and test the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
194,072 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,697のガイドは作成済み
コメント 1 件
Replaced port but phone now doesn't recognise sim can use WhatsApp though
Ann Sayer - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 27
過去 30 日: 125
今までの合計 7,173
