メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy A32 5G Back Cover Replacement
必要な工具と部品
    1. Samsung Galaxy A32 5G Back Cover Replacement, Heat the back cover: 手順 1、 1の画像 1
      • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 1 Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 2 Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: 手順 2、 3の画像 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: 手順 3、 2の画像 1 Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: 手順 3、 2の画像 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: 手順 4、 3の画像 1 Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: 手順 4、 3の画像 2 Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: 手順 4、 3の画像 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    5. Samsung Galaxy A32 5G Back Cover Replacement: 手順 5、 2の画像 1 Samsung Galaxy A32 5G Back Cover Replacement: 手順 5、 2の画像 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    6. Samsung Galaxy A32 5G Back Cover Replacement: 手順 6、 2の画像 1 Samsung Galaxy A32 5G Back Cover Replacement: 手順 6、 2の画像 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
      FixBotに聞いてみる
      コメントを追加
    7. Samsung Galaxy A32 5G Back Cover Replacement, Remove the back cover: 手順 7、 2の画像 1 Samsung Galaxy A32 5G Back Cover Replacement, Remove the back cover: 手順 7、 2の画像 2
      • Remove the back cover.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
19 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
264,673 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
86,241のガイドは作成済み
5件のガイドコメント
What? Where is the rest of this Manual? There's more to a screen replacement then taking the old screen off? There is also components that still need to be swapped over like the Mother board, the Charge Port, the Cameras etc....
BP 674 - 返信 共有
It is only for taking off the BACK. THERE IS ALSO A GUIDE FOR SCREEN REPLACEMENT.
Poli Poli - 返信 共有
I have a question What would cause my bluetooth and my wifi to start randomly stop working after an update from samsung and now i cant goto a further update? or a before update?
Tony Guido - 返信 共有
Absolutely useless, just the first step of 20
Family name - 返信 共有
Just useless, first step of over 20 steps
Family name - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 44
過去 30 日: 198
今までの合計 13,627
