はじめに
Samsung A20e - Broken Screen Replacement
必要な工具と部品
ビデオの概要
Remove the SIM tray
To remove the back cover use a plastic opening tool
When you remove the back cover, press the Touch ID to unstick it from the back cover
With a Phillips Screwdriver remove all the screws
With a Plastic Opening Tool:
Remove the Antenna Assembly
Disconnect and remove the Touch ID Fingerprint Sensor
Remove the Logic Board Plastic Cover
Remove the Sup-board Plastic Cover
Disconnect the Sup-board Flex Cable
Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
Remove the Sup-board Flex Cable
Disconnect the Volume buttons Flex Cable
Gently remove the Logic board. Be careful for the cameras
Now you have to transfer:
Receiber
Vibromotor
Loudspeacker
Remove the transport tapes from:
Silicon Thermal Pad
Front Camera Hole
19 の人々がこのガイドを完成させました。
