はじめに
Follow this guide to replace the USB-C charging port and daughterboard in a Samsung Galaxy A15.
To reassemble the device, you'll need replacement adhesive for the back cover.
必要な工具と部品
Unplug all cables and completely power off the phone.
Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
Apply a suction handle to the back cover, as close to the center of the right edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the right edge between the back cover and the frame to slice through the adhesive.
Leave the opening pick in the bottom right corner to keep the adhesive from resealing.
Insert an opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
Slide the opening pick around the edge of the camera modules to unfasten the remaining camera clips.
Once the adhesive around the edges is loose, insert an opening pick deeper into the bottom edge from the bottom left corner.
Slide the pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
Lift and remove the back cover.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
この手順で使用する道具:iFixit Precision 4 mm Screwdriver Bit$2.99
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
Press in firmly to eject the tray and remove it.
Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
Flip the phone over so the screen is facing up.
Insert an opening pick between the screen and the SIM card tray cutout to form a gap between the frame and the phone.
Slide the opening pick down the left edge of the device to unfasten the frame clips.
Use the flat end of a spudger to lift up and disconnect the battery press connector from the motherboard.
Insert the flat end of a spudger under the overhang of the top "OCTA" cable connector.
Pry up the top connector away from the bottom one until they're disconnected.
Insert one arm of angled tweezers under the metal neck of the red antenna coaxial connector on the daughterboard and lift straight up to disconnect it.
Repeat for the other connector.
この手順で使用する道具:Tesa 61395 Tape$2.99
Insert the flat end of a spudger underneath the flex ribbon connector and pry it off of the board.
Use a Phillips screwdriver to remove the 3 mm‑long screw securing the daughterboard to the phone.
Grab the daughterboard by its edges and pull it up and out of the phone.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
12 の人々がこのガイドを完成させました。
6件のガイドコメント
Could you post another picture from the daughterboard, showing the other side of it? I need to see if that usb-c port has just one or two rows of pads.
Here you go! Let me know if you need additional photos.
Step 18 - You should mention that you start working here on the FRONT of the case. I worked for 10 minutes on he BACK side trying to get the frame clips to release, They don't! I did finally get it all.
Thanks for the feedback, I've edited the step to clarify. Glad you were able to repair your device!
Same thing happened to me on step 18. I was on the back side not the front I used my fingernail to pry it off. It pays to be a classical guitarist with long nails. I was about to give up until I viewed a YouTube tutorial. You are driving customers away from the pros. I bought the part and they wanted to charge me $60 just for labor to install it. Stupid Assurant insurance protection wouldn't cover the USB port so I decided to do it myself. Now who's gonna give me $60?
