必要な工具と部品
Close the phone and flip it on it's back.
Under the SAMSUNG logo there will be a bit of space to open the phone with your fingernail or a tool.
Finally, pull the cover slowly and carefully so it doesn't break.
Put your finger on the space highlighted in red, and press while slowly lifting the old battery.
Next insert the new battery by following the steps above backwards and making sure the SAMSUNG logo is on the top and the pins of the phone align with the contacts of the battery correctly.
To reassemble your device, put the cover back.
ある他の人がこのガイドを完成しました。
