メインコンテンツにスキップ
Samsung GALAXY Note 3 - Service / Test menu
ビデオの概要
  1. Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: 手順 1、 3の画像 1 Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: 手順 1、 3の画像 2 Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: 手順 1、 3の画像 3
    • *#06# - IMEI
    • *#1234# - Version
    • *#12580*369# - Main Version
    • *#0228# - Battery Status
    • *#0808# - USB Settings
    • *#0011# - Service Modes
    • *#0*# - Service / Test / Hidden functions
    • *#9900# - System Dump menu
    not working in my verizon Note 3
    HIREN PATEL - 返信
    Same. - also Verizon unit. (w/unlocked BL) none worked.. - Absolutely LOVE V/branded phones. :D
    Thor - 返信
    Ussd code not displaying,in my Samsung Galaxy note 3 olleh.every time when I display it says try again.help me please.
    lameck emmanuely - 返信
    If Samsung Note 3 Wi-fi is not turn on how to fix it?
    Shahg - 返信
終わりに
93 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
191,308 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,534のガイドは作成済み
16 件のコメント
Does this work with all Galaxy Note 3 phones? I have one from US Cellular and can't seem to get this to work.
atomashaska - 返信
Enter this code first *#22745927 to enable / disable hidden menu.
ZFix -
Yes, unless your mobile phone is installed with a system that is not a Samsung Experience.
zhanbohan2008@qq.com -
You're running a custom ROM. Codes can very between ROMs in certain circumstances. Have you tested these on the stock ROM?
Harley Pisa - 返信
I can not make phone calls with my note 3 after I purchased a activation kit for net10. Im not sure of why is it my apn settings or where do I go from here? I have tried every thing
Donnie King - 返信
could u help me i have samsun glaxy note 3 . when i want to dile number it outomaitcally add +1 then i cant call
i cant calll.
how to remove +1 from my all contact .
engineermasoodazizi - 返信
allso, when i want to from google direct take number then otomatically it added +1
how to remove +1 for contact . i have lots number . when i call , all added +1
pleas help me
please help me my phone is invert colour mode how can change normal mode?
jayasinghpv - 返信
I don't know. You can ask Samsung customer service.
Go to setting type on searche
Inverted and deactivate it .
Ayoubblack Hotmal -
It's Samsung Galaxy note3 and only the touch screen doesn't respond for no reason. I dialed *#0*# nd clicked for touch ….but it didn't work (no hardware damage).Help.
Hannah Baker - 返信
Dear I have N900V samsung Note 3, no any code works on it even *#06#
Pls help
GB KHAN OFFICAL - 返信
I have an /sm_n9005
With a custom room lineàge os àndro pie 9 the self test doesnt come out when i dial *#0*# help
Ayoubblack Hotmal - 返信
I can not make phone calls with my Galaxy j7 after I insert sim card for few calls one or three calls after that “ not registred on network “ command appears on the screen . but the sim card works properly on other phone,I have tried every thing. please help me to fix this problem
eshetu_bkl - 返信
I cannot activate MTN bundles with my Samsung Galaxy Note 3 I can check just credit but to process any other code it cannot
ejabi victor - 返信
Sir my phone mic works on calls with open speaker and not record voice on whattsapp
Malik wajdan ali - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 35
今までの合計 85,766
