はじめに
Use this guide to replace a faulty Vibration Motor.
必要な工具と部品
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
ある他の人がこのガイドを完成しました。
