はじめに
Use this guide to replace a defective Headphone Jack.
必要な工具と部品
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Insert the spudger under each corner ribbon cable and lift them out of the way.
Insert a plastic pry tool into the gap between motherboard and base of phone
Insert flat end of spudger between support panel and front assembly.
Using a spudger pry up to create opening to insert plastic opening tool.
ある他の人がこのガイドを完成しました。
