メインコンテンツにスキップ
Samsung Exhibit II 4G Headphone Jack Replacement
必要な工具と部品
  1. Samsung Exhibit II 4G Headphone Jack Replacement, Battery: 手順 1、 1の画像 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 2、 1の画像 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Headphone Jack Replacement, Top Rear Housing Cover: 手順 3、 1の画像 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 4、 1の画像 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 5、 2の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 5、 2の画像 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 6、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 6、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 6、 3の画像 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Headphone Jack Replacement, Midframe: 手順 7、 1の画像 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 8、 1の画像 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 9、 1の画像 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 10、 1の画像 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: 手順 11、 2の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: 手順 11、 2の画像 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 12、 2の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 12、 2の画像 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Headphone Jack Replacement, Rear Facing Camera: 手順 13、 1の画像 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 14、 2の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 14、 2の画像 2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: 手順 15、 3の画像 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 16、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 16、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 16、 3の画像 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
  17. Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: 手順 17、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: 手順 17、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: 手順 17、 3の画像 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
  18. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 18、 2の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 18、 2の画像 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
  19. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 19、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 19、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 19、 3の画像 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
  20. Samsung Exhibit II 4G Headphone Jack Replacement: 手順 20、 3の画像 1 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 20、 3の画像 2 Samsung Exhibit II 4G Headphone Jack Replacement: 手順 20、 3の画像 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
David R
メンバー登録日: 07/20/15
1,152 ポイント
9のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Rowley SU 2015 Eastern Washington University, Team 1-3, Rowley SU 2015人のメンバー
EWU-ROWLEY-SU15S1G3
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 311
