メインコンテンツにスキップ
Samsung Eternity Digitizer and Screen Replacement
必要な工具と部品
    • Remove the back battery cover.
  1. Samsung Eternity Digitizer and Screen Replacement: 手順 2、 1の画像 1
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Digitizer and Screen Replacement: 手順 3、 1の画像 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Digitizer and Screen Replacement: 手順 4、 2の画像 1 Samsung Eternity Digitizer and Screen Replacement: 手順 4、 2の画像 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: 手順 5、 1の画像 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Digitizer and Screen Replacement: 手順 6、 3の画像 1 Samsung Eternity Digitizer and Screen Replacement: 手順 6、 3の画像 2 Samsung Eternity Digitizer and Screen Replacement: 手順 6、 3の画像 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Digitizer and Screen Replacement: 手順 7、 1の画像 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Digitizer and Screen Replacement: 手順 8、 1の画像 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Digitizer and Screen Replacement: 手順 9、 3の画像 1 Samsung Eternity Digitizer and Screen Replacement: 手順 9、 3の画像 2 Samsung Eternity Digitizer and Screen Replacement: 手順 9、 3の画像 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Digitizer and Screen Replacement: 手順 10、 1の画像 1
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: 手順 11、 1の画像 1
    • Flip phone over so you are looking at the front screen of the phone. (The back is already taken off and parts removed)
  11. Samsung Eternity Digitizer and Screen Replacement: 手順 12、 3の画像 1 Samsung Eternity Digitizer and Screen Replacement: 手順 12、 3の画像 2 Samsung Eternity Digitizer and Screen Replacement: 手順 12、 3の画像 3
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone. This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Digitizer and Screen Replacement: 手順 13、 3の画像 1 Samsung Eternity Digitizer and Screen Replacement: 手順 13、 3の画像 2 Samsung Eternity Digitizer and Screen Replacement: 手順 13、 3の画像 3
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Heather Behrend
メンバー登録日: 04/20/11
133 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G11
5 メンバー
14のガイドは作成済み
3 件のコメント
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - 返信
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 6,863
