メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Epix Keyboard Replacement
必要な工具と部品
  1. Samsung Epix Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Epix Keyboard Replacement: 手順 2、 1の画像 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Epix Keyboard Replacement, Keyboard: 手順 3、 1の画像 1
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Epix Keyboard Replacement: 手順 4、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Epix Keyboard Replacement: 手順 5、 2の画像 1 Samsung Epix Keyboard Replacement: 手順 5、 2の画像 2
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Epix Keyboard Replacement: 手順 6、 1の画像 1
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Epix Keyboard Replacement: 手順 7、 1の画像 1
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Epix Keyboard Replacement: 手順 8、 1の画像 1
    • Gently lift and remove the front faceplate
    • Exercise caution
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Epix Keyboard Replacement: 手順 9、 1の画像 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Chris
メンバー登録日: 04/20/11
32 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G15
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 40
今までの合計 2,036
