メインコンテンツにスキップ
Samsung Epic 4G Touch Motherboard Replacement
必要な工具と部品
  1. Samsung Epic 4G Touch Motherboard Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Motherboard Replacement: 手順 2、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 2、 2の画像 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Motherboard Replacement, microSD Card: 手順 3、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, microSD Card: 手順 3、 2の画像 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch Motherboard Replacement: 手順 4、 1の画像 1
    • Pull the microSD card away from its slot.
  5. Samsung Epic 4G Touch Motherboard Replacement, Battery: 手順 5、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Battery: 手順 5、 2の画像 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  6. Samsung Epic 4G Touch Motherboard Replacement: 手順 6、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 6、 2の画像 2
    • Lift and remove the battery from the midframe.
  7. Samsung Epic 4G Touch Motherboard Replacement, Plastic Midframe: 手順 7、 1の画像 1
    • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
  8. Samsung Epic 4G Touch Motherboard Replacement: 手順 8、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 8、 2の画像 2
    • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
  9. Samsung Epic 4G Touch Motherboard Replacement: 手順 9、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 9、 2の画像 2
    • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
  10. Samsung Epic 4G Touch Motherboard Replacement: 手順 10、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 10、 2の画像 2
    • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
  11. Samsung Epic 4G Touch Motherboard Replacement: 手順 11、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 11、 2の画像 2
    • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
  12. Samsung Epic 4G Touch Motherboard Replacement: 手順 12、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 12、 2の画像 2
    • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
  13. Samsung Epic 4G Touch Motherboard Replacement, Motherboard Connectors: 手順 13、 1の画像 1
    • Headphone jack/vibrator assembly cable connector
    • Front-facing camera cable connector
    • Digitizer cable connector
    • Display cable connector
  14. Samsung Epic 4G Touch Motherboard Replacement, Headphone Jack/Vibrator Connector: 手順 14、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Headphone Jack/Vibrator Connector: 手順 14、 2の画像 2
    • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
  15. Samsung Epic 4G Touch Motherboard Replacement, Motherboard Assembly: 手順 15、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Motherboard Assembly: 手順 15、 2の画像 2
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  16. Samsung Epic 4G Touch Motherboard Replacement: 手順 16、 1の画像 1
    • Carefully disconnect the digitizer display cable.
  17. Samsung Epic 4G Touch Motherboard Replacement: 手順 17、 1の画像 1
    • Use a spudger to disconnect the display cable connector.
  18. Samsung Epic 4G Touch Motherboard Replacement: 手順 18、 1の画像 1
    • Remove the two 3 mm Phillips #00 screws.
  19. Samsung Epic 4G Touch Motherboard Replacement: 手順 19、 3の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 19、 3の画像 2 Samsung Epic 4G Touch Motherboard Replacement: 手順 19、 3の画像 3
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
  20. Samsung Epic 4G Touch Motherboard Replacement, Rear Facing Camera: 手順 20、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Rear Facing Camera: 手順 20、 2の画像 2
    • Use the pointed end of a spudger to flip the tab on the rear-facing camera ZIF connector.
  21. Samsung Epic 4G Touch Motherboard Replacement: 手順 21、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement: 手順 21、 2の画像 2
    • Slide a spudger under the rear-facing camera cable to free it from the adhesive.
  22. Samsung Epic 4G Touch Motherboard Replacement: 手順 22、 1の画像 1
    • Remove the rear-facing camera from the motherboard.
  23. Samsung Epic 4G Touch Motherboard Replacement, Microphone Cover: 手順 23、 2の画像 1 Samsung Epic 4G Touch Motherboard Replacement, Microphone Cover: 手順 23、 2の画像 2
    • The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device.
    • Make sure the microphone cover stays in its slot on the display assembly.
    • When you removed the motherboard, the microphone cover may have remained stuck on the microphone. Put it back in its notch in the display assembly to avoid losing it.
終わりに
13 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
467,548 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,066のガイドは作成済み
コメント 1 件
Sadly, this guide is for the Sprint version of the S II.
The international version has a completely different layout and mainboard. :/
Someone - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 28,342
