この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Show user how to install a new micro USB port into device.
必要な工具と部品
Slide your fingernail along the edge of the device and pull at the plastic backing.
Locate the memory card on the upper right-hand corner of the device.
Remove the memory card from the device by gently sliding it out of its holder with your fingers.
Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
Remove the power button using tweezers if it did not fall out in the previous step.
Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
Snap the antenna assembly out of the device gently using your fingers.
Pry the flex cable from the top of the phone by carefully using a nylon spudger.
Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
8 の人々がこのガイドを完成させました。
コメント 1 件
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
