この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Shower user how to instal a new micro USB port into device.
必要な工具と部品
Slide your fingernail along the edge of the device and pull at the plastic backing.
Locate the memory card on the upper right-hand corner of the device.
Remove the memory card from the device by gently sliding it out of its holder with your fingers.
Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
Remove the power button using tweezers if it did not fall out in the previous step.
Remove the white cable on the right side of the phone (next to the battery housing) using the nylon spudger.
Pull out both ends of the white cable. They should easily snap out of place. Do not rip them out.
Remove the screw holding the antenna assembly in place using a Tri-point Y0 screwdriver.
Snap the antenna assembly out of the device.
Carefully pry the flex cable from the top of the phone using a nylon spudger.
Repeat this step for the larger flex cable located on the left side of the device.
8 の人々がこのガイドを完成させました。
コメント 1 件
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
