メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Epic 4G Micro USB Port Replacement
必要な工具と部品
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: 手順 1、 1の画像 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Epic 4G Micro USB Port Replacement: 手順 2、 1の画像 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: 手順 3、 1の画像 1
    • Remove the battery from the device by pulling the battery edge upwards.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: 手順 4、 1の画像 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: 手順 5、 2の画像 1 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: 手順 5、 2の画像 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: 手順 6、 2の画像 1 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: 手順 7、 1の画像 1
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: 手順 8、 2の画像 1 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: 手順 8、 2の画像 2
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: 手順 9、 2の画像 1 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: 手順 9、 2の画像 2
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Epic 4G Micro USB Port Replacement: 手順 10、 1の画像 1
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
8 の人々がこのガイドを完成させました。
作成者
15人の作成者と共同で作成されました。
Andrew Cunningham
メンバー登録日: 10/03/12
273 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G25
4 メンバー
14のガイドは作成済み
1件のガイドコメント
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 29
今までの合計 2,844
