メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Droid Charge Screen Replacement
必要な工具と部品
  1. Samsung Droid Charge Screen Replacement, Rear Cover: 手順 1、 1の画像 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Droid Charge Screen Replacement, Battery: 手順 2、 1の画像 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Droid Charge Screen Replacement, microSD: 手順 3、 1の画像 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Droid Charge Screen Replacement, SIM Card: 手順 4、 1の画像 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Droid Charge Screen Replacement, Screen: 手順 5、 1の画像 1
    • Locate the 7 small black screws located around the edge of the phone under the battery cover.
    • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Droid Charge Screen Replacement: 手順 6、 1の画像 1
    • Locate your pry tool.
    • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
    • Use a prying motion to lift the casing up.
    • Repeat this motion all around the screen edge until the casing pops off.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Droid Charge Screen Replacement: 手順 7、 1の画像 1
    • Release the one pop connector for the motherboard located on the right.
    • Release the volume button flex cable on the right.
    • Release the power button flex cable on the right.
    • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Droid Charge Screen Replacement: 手順 8、 3の画像 1 Samsung Droid Charge Screen Replacement: 手順 8、 3の画像 2 Samsung Droid Charge Screen Replacement: 手順 8、 3の画像 3
    • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
    • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
    • Work carefully to prevent damage to the phone.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Droid Charge Screen Replacement: 手順 9、 1の画像 1
    • You can now swap out the old screen for your new one.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Luke Gordon
メンバー登録日: 09/26/12
199 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S15G44
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 25
今までの合計 3,480
