メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Droid Charge SIM Card Port Replacement
必要な工具と部品
    1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: 手順 1、 1の画像 1
      • Open up the back case on the phone from the groove in the bottom of the phone.
      • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Droid Charge SIM Card Port Replacement, Battery: 手順 2、 1の画像 1
      • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
      • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Droid Charge SIM Card Port Replacement, microSD: 手順 3、 1の画像 1
      • Push the SD card further into its metal slot until you hear a click.
      • Release the card, and it should automatically eject itself.
      • Remove the SD card.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Droid Charge SIM Card Port Replacement, SIM Card: 手順 4、 1の画像 1
      • Slide the SIM card out of its casing by pushing on it and sliding it upward.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: 手順 5、 1の画像 1
      • Carefully remove the back cover.
      • Remove the two 5mm screws with a small Phillips head screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Droid Charge SIM Card Port Replacement: 手順 6、 1の画像 1
      • Removal of the back half of the casing.
      • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
      • Use a prying motion to lift the casing up. This will separate the phone casing.
      • Repeat this motion all around the screen edge until the casing pops off.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Droid Charge SIM Card Port Replacement: 手順 7、 1の画像 1
      • Release the volume button flex cable on the right.
      • Release the pop connector on the motherboard located to the left of the SIM card port.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Droid Charge SIM Card Port Replacement: 手順 8、 2の画像 1 Samsung Droid Charge SIM Card Port Replacement: 手順 8、 2の画像 2
      • Your SIM card port is now unattached.
      • Remove SIM card port from motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Lucas Carter
メンバー登録日: 09/27/12
190 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S15G44
4 メンバー
36のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 32
今までの合計 2,850
