メインコンテンツにスキップ
Samsung DVD-HD850 Player Power Button Replacement
必要な工具と部品
  1. Samsung DVD-HD850 Player Power Button Replacement, Cover: 手順 1、 1の画像 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Power Button Replacement, Locate and remove screws: 手順 2、 1の画像 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Power Button Replacement, Remove Cover: 手順 3、 1の画像 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Power Button Replacement, Locate and Remove The Disk Tray: 手順 4、 1の画像 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  5. Samsung DVD-HD850 Player Power Button Replacement, Removing The Data Strips: 手順 5、 1の画像 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  6. Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: 手順 6、 3の画像 1 Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: 手順 6、 3の画像 2 Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: 手順 6、 3の画像 3
    • As noted by the red circles, locate and remove the screws one at a time
  7. Samsung DVD-HD850 Player Power Button Replacement, Disk Tray Removal: 手順 7、 1の画像 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  8. Samsung DVD-HD850 Player Power Button Replacement, Success!: 手順 8、 1の画像 1
    • Congrats! You have sucessfully have taken out the disk drive
  9. Samsung DVD-HD850 Player Power Button Replacement, Unscrew power button circuit board: 手順 9、 1の画像 1
    • Unscrew the one screw that is connecting the circuit board to the frame.
  10. Samsung DVD-HD850 Player Power Button Replacement, Remove power button circuit board: 手順 10、 1の画像 1
    • Jiggle the circuit board until it becomes loose from the two prongs holding it in place.
    • Replace with a new one.
終わりに
作成者
1人の作成者と共同作成されました。
Robert Moss
メンバー登録日: 10/22/14
201 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G6
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 261
