メインコンテンツにスキップ
Samsung DVD-HD850 Player Fuse Replacement
必要な工具と部品
  1. Samsung DVD-HD850 Player Fuse Replacement, Cover: 手順 1、 1の画像 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Fuse Replacement, Locate and remove screws: 手順 2、 1の画像 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Fuse Replacement, Remove Cover: 手順 3、 1の画像 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Fuse Replacement, Locate the Circuit Board: 手順 4、 1の画像 1
    • Make sure your device is unplugged before you try to do the following steps to avoid electrocution
    • It is recommended to buy the new power fuse before proceeding with this guide. To buy a power fuse online you can click on the name of the fuse under the "relevant parts" section on the top of this page and it will guide you to a website to buy one
    • With the back panel of the device facing towards you, locate the circuit board inside the device
  5. Samsung DVD-HD850 Player Fuse Replacement, Locate the Power Fuse: 手順 5、 1の画像 1
    • Locate the power fuse on the bottom left of the circuit board
  6. Samsung DVD-HD850 Player Fuse Replacement, Remove the Power Fuse: 手順 6、 1の画像 1
    • To Remove the power fuse from the circuit board, gently pull up on the fuse to remove it from the metal clips
    • The power fuse is very delicate so do not put much force into pulling it from the clips
  7. Samsung DVD-HD850 Player Fuse Replacement, Insert the new Power Fuse: 手順 7、 1の画像 1
    • After removing the old power fuse, put in the new fuse by gently pushing the fuse into the metal clips until it clicks into place
    • The best way to put the new fuse in is by grabbing both ends of the fuse and pushing it in from the ends. Avoid pushing it in from the middle of the fuse to prevent it from breaking
    • If done correctly you should now have full power back in your device!
    • Do not try to power the device on before reassembling the device first
終わりに
作成者
1人の作成者と共同作成されました。
Devon Clements
メンバー登録日: 10/21/14
228 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G6
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 16
今までの合計 4,613
