はじめに
Caution: All alteration or modifications are the users responsibility, and not of the guide creator. These steps are only recommended if not under warranty or if a solution has not yet been found.
必要な工具と部品
Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
ある他の人がこのガイドを完成しました。
