メインコンテンツにスキップ
Samsung DVD-HD850 Player Disk Drive Motor Replacement
必要な工具と部品
  1. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Locate and Remove The Disk Tray: 手順 1、 1の画像 1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Data Strips: 手順 2、 1の画像 1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: 手順 3、 3の画像 1 Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: 手順 3、 3の画像 2 Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing The Screws: 手順 3、 3の画像 3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Disk Tray Removal: 手順 4、 1の画像 1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Success!: 手順 5、 1の画像 1
    • Congrats! You have sucessfully have taken out the disk drive
  6. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Disassemble the motor from the disk tray: 手順 6、 1の画像 1
    • Remove screws as noted by the picture
  7. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Removing Data Strips: 手順 7、 1の画像 1
    • Slowly remove the circuit board/cables/strips from under the black bar. ( under and over)
    • Be careful not to pull it hard, due to these cable are fragile and can break easliy
  8. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Replacing Motor: 手順 8、 1の画像 1
    • Replace the motor in question ( usually both are needed to be replaced)
  9. Samsung DVD-HD850 Player Disk Drive Motor Replacement, Reassembly: 手順 9、 1の画像 1
    • To reassembly do these steps in reverse order
終わりに
作成者
2人の作成者と共同で作成されました。
Carlos
メンバー登録日: 10/16/14
354 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G6
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 9
今までの合計 1,415
