メインコンテンツにスキップ
Samsung DV180F Repair Display Screen Replacement
必要な工具と部品
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: 手順 1、 3の画像 1 Samsung DV180F Repair Display Screen Replacement, Display Screen: 手順 1、 3の画像 2 Samsung DV180F Repair Display Screen Replacement, Display Screen: 手順 1、 3の画像 3
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: 手順 2、 2の画像 1 Samsung DV180F Repair Display Screen Replacement: 手順 2、 2の画像 2
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: 手順 3、 3の画像 1 Samsung DV180F Repair Display Screen Replacement: 手順 3、 3の画像 2 Samsung DV180F Repair Display Screen Replacement: 手順 3、 3の画像 3
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Evan McGettrick
メンバー登録日: 09/24/16
190 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G4
4 メンバー
8のガイドは作成済み
2 件のコメント
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - 返信
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 481
