はじめに
In this guide, I will show you how to replace the hard drive in a Samsung All-in-One Desktop DP515A2G.
必要な工具と部品
Put the Samsung dp515a2g face down on a surface that will not scratch the monitor.
この手順で使用する道具:iFixit Opening Picks (Set of 6)$4.95
Gently insert an opening pick in the seam between the back panel and bezel.
Run the opening pick along the seam, carefully freeing the clips holding the back panel in place.
The back panel should come away without resistance.
この手順で使用する道具:Phillips #000 Screwdriver$5.49
Remove the 3 screws highlighted in red with a 000 Screwdriver
Using the 000 Screwdriver remove the screw on each side.
The hard drive should pull free of the shroud.
4 の人々がこのガイドを完成させました。
