メインコンテンツにスキップ
Samsung Chromebook series 5 XE550C22 SSD Replacement
必要な工具と部品
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 手順 1、 3の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 手順 1、 3の画像 2 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 手順 1、 3の画像 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 2、 2の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 2、 2の画像 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 3、 3の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 3、 3の画像 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 3、 3の画像 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 4、 2の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 4、 2の画像 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 手順 5、 2の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 手順 5、 2の画像 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 6、 2の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 6、 2の画像 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: 手順 7、 1の画像 1
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 8、 3の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 8、 3の画像 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 8、 3の画像 3
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 9、 2の画像 1 Samsung Chromebook series 5 XE550C22 SSD Replacement: 手順 9、 2の画像 2
    • Pull the SSD up and away from the Chromebook
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Abel Osorio
メンバー登録日: 09/11/17
330 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G7
3 メンバー
14のガイドは作成済み
4 件のコメント
Hello where can I get I higher SSD to buy
aduboa moses - 返信
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - 返信
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - 返信
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 30
今までの合計 5,073
