メインコンテンツにスキップ
Samsung Chromebook XE500C21-A03US Battery Replacement
必要な工具と部品
  1. Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: 手順 1、 3の画像 1 Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: 手順 1、 3の画像 2 Samsung Chromebook XE500C21-A03US Battery Replacement, Back Cover: 手順 1、 3の画像 3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 2、 3の画像 1 Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 2、 3の画像 2 Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 2、 3の画像 3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 3、 2の画像 1 Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 3、 2の画像 2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US Battery Replacement, Battery: 手順 4、 2の画像 1 Samsung Chromebook XE500C21-A03US Battery Replacement, Battery: 手順 4、 2の画像 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  5. Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 5、 2の画像 1 Samsung Chromebook XE500C21-A03US Battery Replacement: 手順 5、 2の画像 2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
終わりに
作成者
3人の作成者と共同で作成されました。
Alexis Cortez
メンバー登録日: 09/11/17
228 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team S2-G5, Bruce Fall 2017 CSU Fullerton, Team S2-G5, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 468
