はじめに
If your charger port is broken, this guide will teach you how to take apart your Chromebook and replace the faulty port.
必要な工具と部品
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
10 の人々がこのガイドを完成させました。
2 件のコメント
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
