必要な工具と部品
Hold down the power button until the device powers off
Close the device and flip it over
Remove the four rubber sockets near the corners of the device
Then remove the four 4.6 mm Phillips #00 screws
Face hinges towards you
Pull out the white plug-in piece
Only remove the red and black wire from the wire guide
If the left speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-C(L) R0.0 BA96-07326A"
もう少しです!
終わりに
