メインコンテンツにスキップ
Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement
必要な工具と部品
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: 手順 1、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: 手順 1、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: 手順 1、 3の画像 3
    • Hold down the power button until the device powers off
    • Close the device and flip it over
    • Remove the four rubber sockets near the corners of the device
    • Then remove the four 4.6 mm Phillips #00 screws
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 2、 2の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 2、 2の画像 2
    • Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
    • Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 3、 2の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 3、 2の画像 2
    • Locate the long grey box with the black band, which is labeled "Laptop Battery."
    • Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 4、 1の画像 1
    • Unplug the golden band coming from the battery to the motherboard.
    • Using the Philips #000 remove the four 4mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: 手順 5、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: 手順 5、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: 手順 5、 3の画像 3
    • Face hinges towards you
    • Pull out the white plug-in piece
    • Only remove the red and black wire from the wire guide
    • If the left speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-C(L) R0.0 BA96-07326A"
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 6、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 6、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: 手順 6、 3の画像 3
    • Only remove the white and black wire from the wire guide
    • If the right speaker is broken, lift the black L-shaped piece called ">PC+ABS<S1-A(R) R0.0 BA96-07326B"
終わりに
作成者
2人の作成者と共同で作成されました。
Austyn Akin
メンバー登録日: 09/08/23
261 ポイント
2のガイドは作成済み
チーム
University of New Orleans, Team 3-3, McDonald Fall 2023 University of New Orleans, Team 3-3, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S3G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 52
