必要な工具と部品
Hold down the power button until the device powers off
Close the device and flip it over
Remove the four rubber sockets near the corners of the device
Then remove the four 4.6 mm Phillips #00 screws
Face hinge side towards you
Unscrew three 4.55mm Philips #000 screws (pointed by the arrow heads) from the each of left and right hinges
Pull out the black film connected to the motherboard in the white slot
ある他の人がこのガイドを完成しました。
