メインコンテンツにスキップ
Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement
必要な工具と部品
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: 手順 1、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: 手順 1、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Hold down the power button until the device powers off
    • Close the device and flip it over
    • Remove the four rubber sockets near the corners of the device
    • Then remove the four 4.6 mm Phillips #00 screws
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 2、 2の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 2、 2の画像 2
    • Use the metal spudger to pop the back off. Near the hinges is typically an easier place to start.
    • Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 3、 2の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 3、 2の画像 2
    • Locate the long grey box with the black band, which is labeled "Laptop Battery."
    • Remove the gray piece labeled "bracket battery BA61 - 03983A" located over the golden band connecting the battery and motherboard by unscrewing the two 4 mm Phillips #00 screws
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 4、 1の画像 1
    • Unplug the golden band coming from the battery to the motherboard.
    • Using the Philips #000 remove the four 4mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: 手順 5、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: 手順 5、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: 手順 5、 3の画像 3
    • Unplug the black and red wire and the black and white wire.
    • Unclip and remove the black and gold ribbons and the black wire from the motherboard.
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 6、 3の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 6、 3の画像 2 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the three 4.53 mm Philips #00 screws from the grey metal piece labeled "BRKT-PORT-SUB JOAN-15 BA61-03942A".
    • Remove the 4.50 mm Philips #00 screw from the right side of the motherboard.
  7. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the two 4.56 mm Philips #00 screws from the copper heat sink.
    • Remove the four 4.63 mm Philips #00 screws
  8. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 8、 2の画像 1 Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: 手順 8、 2の画像 2
    • Carefully turn the motherboard and heat sink over being careful not to touch any of the components.
    • Remove the four 4.63 mm Philips #00 screws from the back of the motherboard and remove the heat sink.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Katherine Vu
メンバー登録日: 09/08/23
366 ポイント
3のガイドは作成済み
チーム
University of New Orleans, Team 3-3, McDonald Fall 2023 University of New Orleans, Team 3-3, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S3G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 142
