はじめに
This guide illustrates how to remove the Samsung Chromebook 3 XE500C13-K02US battery. You will need to open the device’s back panel as the battery is located inside the case.
必要な工具と部品
Place the laptop back cover facing up to expose the screws.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
