はじめに
This is a step-by-step guide to removing the track pad of the Samsung Chromebook 3. Prior to beginning this guide, you will need to remove the bottom case and the battery.
必要な工具と部品
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
