はじめに
This guide will show you how to replace the daughterboard in a Samsung Chromebook 3. The right side USB and headphone jack are soldered to the board, requiring a full daughterboard replacement to fix a malfunctioning port.
Place the Chromebook face down so that the bottom case is exposed.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
ある他の人がこのガイドを完成しました。
