メインコンテンツにスキップ
Samsung Chromebook 2 XE503c12 Trackpad Replacement
必要な工具と部品
  1. Samsung Chromebook 2 XE503c12 Trackpad Replacement, Trackpad: 手順 1、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement, Trackpad: 手順 1、 2の画像 2
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all nine 5.5 mm screws from the back cover.
  2. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 2、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 2、 2の画像 2
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 3、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 3、 2の画像 2
    • Slowly pry off the back cover of the Chromebook.
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 4、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 4、 2の画像 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  5. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 5、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 5、 2の画像 2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  6. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 6、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 6、 2の画像 2
    • Using a Phillips #00 screwdriver, remove all of the two screws keeping the trackpad in place.
  7. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 7、 3の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 7、 3の画像 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 7、 3の画像 3
    • Gently remove the connector between the trackpad and the motherboard by pulling upward on it at the port.
  8. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 8、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 8、 2の画像 2
    • Using an opening tool, gently peel back the adhesive strip holding the trackpad in place.
  9. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 9、 3の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 9、 3の画像 2 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 9、 3の画像 3
    • Using the opening tool, disconnect the metal trackpad support brackets.
    • Don't be afraid to use a moderate amount of force when prying the support brackets loose.
  10. Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 10、 2の画像 1 Samsung Chromebook 2 XE503c12 Trackpad Replacement: 手順 10、 2の画像 2
    • With the laptop slightly open, push the trackpad upwards at the rear, and pull it out from the bottom.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Shane Solomon
メンバー登録日: 05/22/19
181 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Wilson Summer 2019 IUPUI, Team S1-G1, Wilson Summer 2019人のメンバー
IUPUI-WILSON-SU19S1G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 176
