はじめに
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
必要な工具と部品
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
