はじめに
Sometimes the earpiece can become damaged or loose and needs to be replaced. Follow this guide to fix this problem.
パーツ
パーツは指定されていません。
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Use a spudger to disconnect the three highlighted connectors.
Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
2 の人々がこのガイドを完成させました。
