この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
必要な工具と部品
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
3 の人々がこのガイドを完成させました。
2 件のコメント
Is this for the front facing camera
tracy mann - 返信
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
