メインコンテンツにスキップ
Samsung Captivate Camera Assembly Replacement
必要な工具と部品
  1. Samsung Captivate Camera Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Camera Assembly Replacement: 手順 2、 1の画像 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Camera Assembly Replacement: 手順 3、 1の画像 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: 手順 4、 1の画像 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Camera Assembly Replacement: 手順 5、 1の画像 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Camera Assembly Replacement: 手順 6、 3の画像 1 Samsung Captivate Camera Assembly Replacement: 手順 6、 3の画像 2 Samsung Captivate Camera Assembly Replacement: 手順 6、 3の画像 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Camera Assembly Replacement: 手順 7、 1の画像 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: 手順 8、 1の画像 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  9. Samsung Captivate Camera Assembly Replacement: 手順 9、 1の画像 1
    • Gently lift the camera assembly out of the plastic housing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Drew Bentz
メンバー登録日: 09/22/11
565 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G25
3 メンバー
9のガイドは作成済み
2 件のコメント
Is this for the front facing camera
tracy mann - 返信
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 2,332
