Pull the imaging unit out of the printer using bottom handle.
Use green handle on top of imaging unit to steady unit as you pull it out.
Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
