Lift up the top portion of the battery and pull it out.
Next, slide the sim card out of its socket and set it aside.
Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
The top two screws are connected to the back cover. They will not come off once unscrewed.
Remove the case by prying around the edges.
Note the positions of button pads for reassembly.
Use a prying tool to detach the motherboard from main body.
Carefully detach the motherboard from the two connectors.
You could also use a pry tool for the second step.
Be careful with the motherboard as not to scrape or damage its components.
Slide the keyboard straight up to free it from its alignment pins.
Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
