メインコンテンツにスキップ
Samsung Blast Keyboard Replacement
必要な工具と部品
  1. Samsung Blast Keyboard Replacement, At a Glance: 手順 1、 2の画像 1 Samsung Blast Keyboard Replacement, At a Glance: 手順 1、 2の画像 2
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: 手順 2、 2の画像 1 Samsung Blast Keyboard Replacement, Battery Case Removal: 手順 2、 2の画像 2
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: 手順 3、 1の画像 1
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: 手順 4、 2の画像 1 Samsung Blast Keyboard Replacement, Back Case Removal: 手順 4、 2の画像 2
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: 手順 5、 2の画像 1 Samsung Blast Keyboard Replacement, Button Pads: 手順 5、 2の画像 2
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: 手順 6、 3の画像 1 Samsung Blast Keyboard Replacement, Motherboard Removal: 手順 6、 3の画像 2 Samsung Blast Keyboard Replacement, Motherboard Removal: 手順 6、 3の画像 3
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: 手順 7、 2の画像 1 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: 手順 7、 2の画像 2
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
終わりに
作成者
8人の作成者と共同で作成されました。
Jordan Taylor
メンバー登録日: 02/11/14
10 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014人のメンバー
OSU-BUEHL-S14S1G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 277
