Use the spudger to loosen and separate the front and back covers.
Pick up the back cover once loosened.
The front and back covers will be attached to each other by a gold wire.
Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
Lift up on the motherboard and it will come free of the front casing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
