はじめに
Use this guide to install, remove, or replace the phone's keypad.
必要な工具と部品
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
もう少しです!
終わりに
